Post by 2smokeruck on May 27, 2019 16:29:55 GMT -5
Ported Stage6 Streetrace, 21mm stage6 pwk and Yasuni R. What jetting do you guys recommend starting off with? I have a 42 and a 110 in it now.
Post by Lucass2T on May 28, 2019 14:18:57 GMT -5
140 and work your way down
Post by ryan_ott on May 28, 2019 15:42:13 GMT -5
I’d pick up some different needles also. Part throttle is what kills many 2 strokes.
Post by 2smokeruck on May 28, 2019 17:32:30 GMT -5
140 and work your way down Damn that high? I guess im gonna spend a lot more on jets than i thought. I did think about the needles though.
Post by benji on May 28, 2019 22:38:05 GMT -5
140 and work your way down Damn that high? I guess im gonna spend a lot more on jets than i thought. I did think about the needles though. find a kit with increments of 5, i.e. 140, 135, 130, etc. 110 is probably lean on mj I bet, and I bet 42 is rich on pj. I'm currently using a jjh needle with a similar carb.
Post by benji on May 28, 2019 22:38:32 GMT -5
Post by Lucass2T on May 29, 2019 0:39:21 GMT -5
140 and work your way down Damn that high? I guess im gonna spend a lot more on jets than i thought. I did think about the needles though. Yeah why not? Why not go to your local dirtbike dealership and buy 140, 130 and 120 and see which one works best. Then buy another three jets and do the same. And repeat that cycle again. You should be able to get the jetting right that way within 10 jets. All the other ones you can give back or the unused ones traded in for other sizes.
Post by 2smokeruck on May 29, 2019 10:08:26 GMT -5
I'll see what i can figure out as far as the dealership. Theres not many of them here. The carb was on my friends ruckus wideband tuned and he was using the 42pj. If i can get this thing started this weekend i will be VERY happy!
Post by pinkscoot on May 29, 2019 18:25:37 GMT -5
What carb do you have? A Ruckus is a 4t and you are posting in the 2T troubleshooting.
Post by 2smokeruck on May 29, 2019 20:13:33 GMT -5
I said the carb was on a ruckus before but its going on my 70cc jog. Its a 21mm stage6 pwk. Question about spark plug. Do i leave the little nipple at the tip? Boot wont fit with it on
Post by repherence2 on May 29, 2019 20:36:09 GMT -5
Ported Stage6 Streetrace, 21mm stage6 pwk and Yasuni R. What jetting do you guys recommend starting off with? I have a 42 and a 110 in it now. or you can buy hobby micro drill set from a hobby store. they are # drill bits. they are so small that they are designated by a # (as opposed to a fraction or letter size drill bit.) you can take a jet (stock or smaller than the 110 jet you are using now) and progressively drill it out and test. each time you go up a drill size, install and test it. if you know that the 110 is too small right now, you can start drilling that jet. I bought a bunch of stock used jets from a local shop and used those jets for drilling/tuning. there are charts on the internet that correlates the # drill diameter to a jet size. use that information to buy the specific size jet.
Post by tsimi on May 29, 2019 20:47:35 GMT -5
What airfilter are you using? Open sponge type or stock airbox?
Post by 2smokeruck on May 29, 2019 20:50:04 GMT -5
Ported Stage6 Streetrace, 21mm stage6 pwk and Yasuni R. What jetting do you guys recommend starting off with? I have a 42 and a 110 in it now. or you can buy hobby micro drill set from a hobby store. they are # drill bits. they are so small that they are designated by a # (as opposed to a fraction or letter size drill bit.) you can take a jet (stock or smaller than the 110 jet you are using now) and progressively drill it out and test. each time you go up a drill size, install and test it. if you know that the 110 is too small right now, you can start drilling that jet. I bought a bunch of stock used jets from a local shop and used those jets for drilling/tuning. there are charts on the internet that correlates the # drill diameter to a jet size. use that information to buy the specific size jet. Ive tried that on another scoot but i just ordered a set of jets. I have a sponge filter but its not gonna fit so im gonna have to run a velocity stack with a screen.
Post by benji on May 29, 2019 21:09:15 GMT -5
I said the carb was on a ruckus before but its going on my 70cc jog. Its a 21mm stage6 pwk. Question about spark plug. Do i leave the little nipple at the tip? Boot wont fit with it on carbs for 2t bikes and 4t bikes are not the same or interchangeable, including aftermarket pwk carbs. There are different parts Internally; either the carb was incorrect for the 4t ruckus and therefore incorrectly jetted, or the carb is incorrect for a 2t jog and will NEVER be correctly jetted. Also, stage6 pwk carbs are actually Koso carbs and are somewhat known to have leaks, i.e. base gasket or there gaskets.
Post by benji on May 29, 2019 21:12:33 GMT -5
I have a sponge filter but its not gonna fit so im gonna have to run a velocity stack with a screen. I would go ahead and spend $20 on a uni filter. Velocity stacks are actually meant to have a filter clammped onto the end, and a velocity stack with no filter will be VERY difficult to tune, especially the mid range and idle. You'll always be lean or rich, never stochiometric.
