Post by jayroid on Jun 4, 2019 12:38:47 GMT -5
Hello again..Does anyone know what size throttle cable I need for a 2016 Taotao 50 ?
Post by GrumpyUnk on Jun 5, 2019 11:42:51 GMT -5
I figure you are concerned with the overall length, and most generic cables should fit. You can approximate the 'sheath' length by following a path from the handlebar, down the tree, under the footrest area, up and around the carburetor. Any excess length(within reason) can be looped towards the rear tire. I think 75" is the minimum that will work, but don't bet your paycheck. Be aware that some newer cables, (or outliers?) don't have the adjuster fittings at both ends of the cable. Instead they use a screw to hold the cable into the handlebar control(sheath) by use of a flat plate instead of the adjuster. tom
