Post by superbrita on Jun 4, 2019 17:59:00 GMT -5
Hi i have a question:
so i got bigger kit (70cc) and when its cold it runs like crazy,it has so much power.
But when i ride it for about 5-10 minutes (i live in the mountains) it starts to kinda lose power and starts accelerating slower.
Also it starts to ping.
Sometimes when its been ridden for about 15 minutes it even struggles to climb small hills(especially when its been ridden with 2 people).
But when its cold it can climb step hills,even with 2 people, fast and with a lot of power. My scooter is chinese with 70cc taiwanese kit and 4,5gr,air cooled.
Help me pls.
Post by pinkscoot on Jun 4, 2019 19:13:22 GMT -5
When you did the new kit did you up jet the carb?
mattyslimz
Post by mattyslimz on Jun 4, 2019 21:04:42 GMT -5
As pinkscoot said I would do some jetting changes considering your elevation. I would also check your belt wear and feel your CVT cover to see how hot it gets after a hill climb. The components inside I.e pulleys, clutch, belt will not perform as well overheated. The taskbars on the left have plenty of info containing guides to CVT tuning/troubleshooting.
Post by superbrita on Jun 5, 2019 6:18:01 GMT -5
Yeah i will try with bigger jets but after 20 minutes of ride my cvt cover is really hot. There is some plastic cover on my cylinder and i noticed it blows hot air straight to my air filter cover and to my cvt intake. Should i remove the plastic cover
Post by pinkscoot on Jun 5, 2019 7:19:23 GMT -5
No!!! its your cooling shroud. Removing it will fry the engine.
Post by superbrita on Jun 5, 2019 8:35:09 GMT -5
yeah ok thanks.
Post by jackrides on Jun 5, 2019 11:18:45 GMT -5
Can you direct the hot air away from those intakes?
Post by superbrita on Jun 5, 2019 13:38:10 GMT -5
Im currently thinking of some way to redirect hot air to blow only to the ground without making my engine overheat or other problems
