Post by ryan_ott on Jun 8, 2019 21:36:51 GMT -5
Clean the float needle and seat. Are you using a fuel filter?
Post by SMALL CC TEK on Jun 8, 2019 23:20:14 GMT -5
Pull it apart and see if the float is out of adjustment . Or if it just moves freely first then check for proper height adjustment of float. I have no idea what the spec is on that carb it's in the directions or spec sheet that came with it hopefully . Some times the pin holding the float is installed at the factory super tight and it holds the float open ,if not just a adjustment ..
