Post by snakeplissken on Jun 12, 2019 9:00:02 GMT -5
I finally rebuild my scooter motor. I installed an 19 mm Arreche Carburetor. I'm using a pod filter 95 main jet and went one up on the pilot jet. The carb needle is set on top notch. Scooter seems too rich in the mid after i went one up on the pilot to smooth out idle. What number needles do i need to go one or two up. Maybe even one or two down if i change the pilot jet again.
Post by jackrides on Jun 12, 2019 11:31:43 GMT -5
Did you play with, oops I mean adjust, the low speed mixture screw with the old pilot jet?
