Post by fitzgr8 on Jun 19, 2019 15:37:48 GMT -5
I just acquired a Qlink star 50 scooter and was wondering if anyone out there might have a part # for the float needle on this carb? The carb bore measures 18.6mm and has JET50 stamped just below where the slide cover plate attaches to the carb.
Thanks, Fitz
Post by 90GTVert on Jun 20, 2019 9:08:26 GMT -5
Post by fitzgr8 on Jun 23, 2019 14:13:43 GMT -5
So I got the new needle and now the carb overflows gas. Does anyone know what the float height should be? Also, should I be able to blow through the fuel valve? I think that might be my problem.
Thanks
Post by SMALL CC TEK on Jun 23, 2019 14:44:34 GMT -5
Yep lower it till it stops leaking fuel ! Most Chinese scooters have no serious service manuals because they use so many different parts suppliers for the same product or model .. One model scooter may have 3 different carbs it uses . Basically when one supplier runs out they just move on and use a new supplier that makes it hard on us ! lol
Post by fitzgr8 on Jun 25, 2019 13:05:34 GMT -5
Figured it out. The o-ring on the seat was bad causing gas to slip by it flooding the carb. Replaced the o-ring, filled it up with gas and it started right up with no problems.
