neogie
Reed valve
Jun 21, 2019 23:27:07 GMT -5
via mobile
Post by neogie on Jun 21, 2019 23:27:07 GMT -5
Hi guys got a 1e40qmb minarelli type scoot with 70cc stage6 pro cylinder. Question is, can i put a reeed valve on it to improve throttle response? It didn't come with a reed valve in the first place so was wondering would this upgrade be worth a try?thanks much
Post by pinkscoot on Jun 22, 2019 9:49:12 GMT -5
It had to have a reed valve originally, all Minarelli scooters come with them.
Post by aeroxbud on Jun 22, 2019 13:37:28 GMT -5
The reed valve is between the carb, and cylinder. Fitting a better quality one will improve response.
neogie
Reed valve
Jun 22, 2019 16:08:31 GMT -5
via mobile
Post by neogie on Jun 22, 2019 16:08:31 GMT -5
It's just weird it didn't come with the reed when i bought this scoot. It usually lies in bwtween the cylinder and the intake manifold on top of it right? And does it need to have a gasket by yh way to seal? I will buy one and see if it makes a much better throttle response on take off. Thanks
Post by aeroxbud on Jun 22, 2019 16:37:35 GMT -5
Yes there should be a gasket.
neogie
Reed valve
Jun 22, 2019 17:27:01 GMT -5
via mobile
Post by neogie on Jun 22, 2019 17:27:01 GMT -5
Thanks. And does the gasket go in between the cylinder and reed? Or between the reed and intake manifold?thanks much
Post by aeroxbud on Jun 22, 2019 18:15:52 GMT -5
Between the cylinder and reed valve cage. The carb intake is rubberized, so makes its own seal.
neogie
Post by neogie on Jun 22, 2019 19:10:29 GMT -5
Thanks bud, really appreciate the help.
