Post by stancejontland on Jul 1, 2019 22:46:22 GMT -5
I dont think its cracked or stretched just too big for the carb nipple. But im sure it needs replacement. First thing i gotta get that flywheel puller. Would that one in the link fit my flywheel? Its a 139qmb or whatever motor.
Post by aeroxbud on Jul 2, 2019 0:40:11 GMT -5
Like Ryan said get some proper clamps. You will always have trouble using the wrong clips. I got different size ones from eBay
Post by aeroxbud on Jul 2, 2019 0:48:29 GMT -5
The pipe probably has got bigger. When new it should of been a fairly tight fit. In the oil pump delete tutorial Brent did he said You'll need a 27mm x 1.0 left handed thread puller to remove the flywheel.
Post by stancejontland on Jul 2, 2019 13:21:31 GMT -5
Are those the clamps that you pinch together to loosen then let go to make tight. Like on a cars cooling system?
Post by aeroxbud on Jul 2, 2019 14:16:10 GMT -5
Post by stancejontland on Jul 2, 2019 16:13:28 GMT -5
Yeah thats what i thought they were. Where is a good place to get new lines? And i wonder if 90g has a video of flywheel removal.
Post by aeroxbud on Jul 3, 2019 0:31:59 GMT -5
Yeah thats what i thought they were. Where is a good place to get new lines? And i wonder if 90g has a video of flywheel removal. He sure does
Post by aeroxbud on Jul 3, 2019 1:41:12 GMT -5
Post by stancejontland on Jul 3, 2019 2:27:10 GMT -5
i think that is a Canadian site. but im close to Canada kind of. i beliebe you said i need 2.5mm. the one on that site is 3.5mm
Post by aeroxbud on Jul 3, 2019 5:03:10 GMT -5
It's 3mm. I don't think 1/2 a millimetre would make much difference. I have always brought 2.5mm, which is standard Yamaha size oil pipe. I couldn't see any on parts for scooters. Perhaps fugaziiv can give you a link. Nice buy that he is
Post by stancejontland on Jul 3, 2019 14:57:41 GMT -5
So in 90gs vid after i get that flywheel off will the pump be obvious to see?
Post by aeroxbud on Jul 3, 2019 15:08:19 GMT -5
This is the oil pump removal thread Brent did. It shows you the pump, and the line you need to change. 49ccscoot.proboards.com/thread/564 you could just trace the oil line back from the carb to be sure.
