Post by ryan_ott on Jul 5, 2019 22:08:35 GMT -5
All of the 360 intakes I’ve used (Malossi and Polini) were like that and the rubber doesn’t last long until it starts to crack.
Post by ryan_ott on Jul 5, 2019 22:27:17 GMT -5
It’s not that they are bad intakes you may just need to find means to support it if you have a lot of movement. With an air box in place that should be good enough to keep the movement down. Just periodically check it for cracks just like you would any other intake.
