Post by zanegrey on Jul 6, 2019 14:48:59 GMT -5
hi all. new to site. I just picked up a 01 hyosung sd50 2 stroke scooter. it has a now spark condition. I am having trouble finding parts that . I am thinking it is the cdi which is a 6 pin one plug and is ac I think.. if any one knows for sure if it is ac or dc I would appreciate you posting that info. I know it is Korean and I think it is a copy of the Suzuki ae 50 .. I have read a couple of post that says it is a morini copy. the stator is all internal .. I mean even the trigger is mounted underneath the flywheel. no other on I have seen is like that..to date any way.. looking forward to any info on parts and or specs I can get.. cool site . thank you
Post by tortoise2 on Jul 6, 2019 15:21:29 GMT -5
having trouble finding parts Potential resource link.
Post by pinkscoot on Jul 6, 2019 15:33:50 GMT -5
Those are great solid scooters , there isn't a big selection of go fast parts for them but they are out there. I had a Hyosung SF50 engine and learned that the CDI on that was proprietery and it would only run with their CDI. I found that Heeters, an old Hyosung dealer had parts they were selling. Here is a link www.heeters.com/CDI.shtml. First I would confirm that your stator is good and that your plug and coil are doing their job. Here is a link to Brents guide to a no start condition that will help you test everything: 49ccscoot.proboards.com/thread/647?page=1#8069. Go through everything first before you put a new CDI on it, the old one may not be the problem.
Post by repherence2 on Jul 7, 2019 10:20:00 GMT -5
is the coil plugged in?
is the spark plug wire firmly plugged in to the spark plug?
Post by zanegrey on Aug 24, 2019 21:16:01 GMT -5
had to put it on the shelf for now. I did find the cdi.. you were right about it being proprietary ..more like predatory...
the numbers I get from the stator are a bit confusing..
looking to try a 6 pin 2 stroke sdi and pin it myself.. i'll post when I do..
thank you all...
