Post by ludlow66 on Jul 6, 2019 15:42:07 GMT -5
I have a newer future champ. 50cc. it starts but problem with idle. Problem started few weeks ago was getting difficult to start. Then would not start. I did the valve ajustment to .004. Note, top valve was almost closed. Anyway, starts now but idles high then low and high and low. I have replaced carb, plug, cdi, coil, cant get it to run normal. any ideas?
Thanks J.
Post by tortoise2 on Jul 6, 2019 16:28:18 GMT -5
replaced carb, plug, cdi, coil, cant get it to run normal Stock or *"performance"* type of CDI? The engine SHOULD idle high for a few minutes (back wheel MAY turn) until enricher pin extends and cuts off supplemental fuel flow.
Post by ludlow66 on Jul 11, 2019 10:05:39 GMT -5
I have tryed both stock and pro cdi.. Not much difference.
Post by scooterpimp on Jul 11, 2019 13:30:40 GMT -5
If idle hunts check for possible vacume leak , hoses , intake elbow etc. just tossin ideas out there
