fdvd
Scoot Junior
Post by fdvd on Jul 8, 2019 7:48:13 GMT -5
Hi guys. Got a SYM Jet EuroX 50. I'm trying to make it run but it won't. Checked the compression - about 6/7bars (100 psi). Checked the spark - there is.
Well, there is compression and spark. After putting some fuel to the cylinder, nothing happen. It doesn't even smoke. The spark plug is wet - fuel line is ok, carb cleaned 2 times already. Try with and without exhaust - nothing. Checked the flywheel and stator. The crankcase spline is ok, the stator too i think. Scoot has DC CDI so i checked pick-up coil - 100 Ohms, it's ok. Gap between flywheel and pick-up coil - seems to be ok, but I will make it closer soon.
What's your suggestions about it? What can be a problem there?
lupo76
Post by lupo76 on Jul 8, 2019 9:20:40 GMT -5
How long it was standing?
Mostly oil drips slowly down into the crank case when they sit for very long time.. Let it start with a hooked up battery for a minute without plug (plug must be on spark plug cable anyways due to resistance oc coil, might be damaged if not) and see what comes out the spark plug hole.
fdvd
Scoot Junior
Post by fdvd on Jul 8, 2019 9:49:16 GMT -5
I already took off top end. The cylinder and head. Check piston, piston rings, pin and bearing. Nothing that could make this engine not running. It was running like 2/3 weeks ago. Then it stand without cylinder and now I put everything together. I think there isn't oil in case, rather fuel (gas mixed with 2Stroke oil) as spark plug is wet.
Post by tortoise2 on Jul 8, 2019 9:56:45 GMT -5
Timing? Insert a probe into spark plug hole, position piston at top-dead-center, then observe if flywheel T-mark is aligned with case indicator. Sometimes the flywheel-crankshaft woodruff key shears which throws off spark timing. While the carb was off for cleaning, did you also inspect the reeds?
fdvd
Scoot Junior
Post by fdvd on Jul 8, 2019 10:04:04 GMT -5
Reed valve was ok when I install it, but I will re-check it. I check pick-up, stator, flywheel and key on the crankshaft - everything seems ok. Also flywheel is exacly at T. Not sure about spark timing as I haven't timing lamp.
I measure voltage from pick-up - 0.2VAC and 107 Ohms -seems to be ok.
Maybe spark is too weak to fire mixture under pressure.
lupo76
Post by lupo76 on Jul 9, 2019 7:22:46 GMT -5
I already took off top end. The cylinder and head. Check piston, piston rings, pin and bearing. Nothing that could make this engine not running. It was running like 2/3 weeks ago. Then it stand without cylinder and now I put everything together. I think there isn't oil in case, rather fuel (gas mixed with 2Stroke oil) as spark plug is wet. Please also check what I said. Typical struggle on these engines...
fdvd
Scoot Junior
Post by fdvd on Jul 9, 2019 8:13:53 GMT -5
Will check it for a while. You mean run via electric starter to make sure the case is empty? Can I have vaccum line from the cylinder doen't connected? I disassemble fuel pump.
lupo76
Post by lupo76 on Jul 9, 2019 8:46:12 GMT -5
You wont built up pressure if you take off that hose. At least put a screw in the hose to seal it.
fdvd
Scoot Junior
Post by fdvd on Jul 9, 2019 9:21:40 GMT -5
Scoot finally give some signs of life. Spark is constantly wet but it was running for 1 second. Is it carb fault that spark plug is wet?
Post by pinkscoot on Jul 9, 2019 11:43:12 GMT -5
Did you seal up the vacuum hose that was mentioned a few posts back? 2T's really need a well sealed system, any leaks will cause them to not start or run badly.
fdvd
Scoot Junior
Post by fdvd on Jul 9, 2019 12:55:55 GMT -5
Yes, I did. After that, it was running for second and not anymore. Spark plug was wet so make it dry with a heatgun and gave hot spark plug into cylinder and nothing again.
Post by geoffh on Jul 9, 2019 15:25:26 GMT -5
So it,s not dead :)but if you have taken the engine apart you need to check your work"cleaning the carb " is not a quick spray and a wipe you need to check every hole and channel is clear.Also make sure the air box is connected and sealed before you try to start it.over on the left is a directory use this to find the no start solver.Keep in touch.
fdvd
Scoot Junior
Post by fdvd on Jul 11, 2019 16:24:59 GMT -5
The scoot is running. Won't move when I got mixture screw at 1,5 turns. When screwed on to the max it start to move. ATM scoot is smoking a lot. I will mount airbox, kickstart and stuff I have been disassemblied. Is smoking fault of lack of airbox, bad carb setting or leakings? What's your thoughts?
Post by repherence2 on Jul 11, 2019 19:54:58 GMT -5
The scoot is running. Won't move when I got mixture screw at 1,5 turns. When screwed on to the max it start to move. ATM scoot is smoking a lot. I will mount airbox, kickstart and stuff I have been disassemblied. Is smoking fault of lack of airbox, bad carb setting or leakings? What's your thoughts? all that smoke is caused by leak-by of 2 stroke oil from the injection pump. the oil leaks by and ends up at the bottom of the crankcase. it happens when a 2 stroke scoot with oil injection pump sird for a while. lupo76 mentioned that earlier.
fdvd
Scoot Junior
Post by fdvd on Jul 12, 2019 2:46:38 GMT -5
I run it with mixed fuel instead of clean gas. I leave pump oil and all hoses from it not connected. I seal vaccum hose from fuel pump, and I don't even use fuel pump at that time. Will check if I make correct mixed fuel and check there isn't any leaking air.
