Post by bfult89 on Jul 11, 2019 7:39:55 GMT -5
Hi guys new to this forum kinda need aome help had a small crash on my scooter make a long story short it wont run now ive check spark fuel compression is about 145psi changed out the carb witb a brand new one to eliminate that everything seems to be operating as it should by that i mean engin turns over all light work horn everything just wont fire up even if i spray carb or starting fluid in there im at a loss ready to give up but i cant ive had this 2004 scooter for many years and never had a problem theres about 5000 miles on it open to any suggestion please help
Post by dexameth on Jul 11, 2019 8:33:18 GMT -5
Hmm... did any vacuum lines come disconnected leaving you over-lean?
Did your spark plug wire come disconnected either from the cap or the coil, or even simply fall off the spark plug itself?
Post by bfult89 on Jul 12, 2019 10:56:51 GMT -5
I checked spark and it sparks. Good i guess im going to buy a new spark plug just because ive never changed it in about 5 years and after me teying to start it i pulled the plug and it is wet with fuel
