Post by cavboy1980 on Jul 19, 2019 15:09:33 GMT -5
I'm screwing together the engine on my now 70cc AC Neos but can't remember how the spring on the centre stand locates. I've got the small pin on the stand itself but can't figure out where it locates on the CVT case. Can anyone please post a picture to help? Thanks
Post by aeroxbud on Jul 19, 2019 16:30:10 GMT -5
There is a small tab sticking out. It is not very big. If you put the spring onto the rod. Then close the stand it should not be far away. About an inch. It might be easier to put the spring in the tab. Then fit the spring to the rod. Push the rod through the stand till it nearly sticks out of that side. Then you can pull on the stand to align the hole. I have fitted it this way, and with a spring puller. I found it easier as described. Though still a pain to fit with the standard spring.
If you still can't find it I will take a picture tomorrow
Post by cavboy1980 on Jul 21, 2019 14:04:38 GMT -5
Fixedit, thanks for the info it helped my sanity........well, until another issue arose (new thread posted)
