ap16
Post by ap16 on Jul 24, 2019 7:35:52 GMT -5
So...I've been noticing that the scooter still moves, sometimes at like 10 mph, when the throttle is closed, or allegedly closed. I'm not sure what is going on.
Post by supascoot on Jul 24, 2019 8:33:46 GMT -5
What rpm is it idling at.. may need cable or throttle adjustment. Could also be clutch springs.. little more info would help.
Post by repherence2 on Jul 24, 2019 20:21:10 GMT -5
take the air box off and visually verify that your carb slide is fully shut at zero throttle. if it's not fully shut, then you have to adjust your cable as mentioned earlier in the previous post.
maybe you need to adjust your idle.
you might want to inspect the CVT. maybe a clutch spring broke.
ap16
Post by ap16 on Jul 25, 2019 21:47:24 GMT -5
When I started the engine cold its idling around 1500 rpm. When riding, its idling at about 3300 rpm. I'll check the carb slide and post.
ap16
Post by ap16 on Jul 30, 2019 10:58:03 GMT -5
So I took the carb off and cleaned it, replaced the fuel filter and fuel lines, now it won't start. It's improved but there was no fuel leaving the tank. I got some regular fuel line and filter that fit.
Post by 90GTVert on Jul 30, 2019 14:55:05 GMT -5
Does it have a vacuum petcock? Maybe some hoses got switched around?
