Post by matlock on Aug 15, 2019 18:30:42 GMT -5
what exhaust will go best for me im 165 lbs Adly RT50 2 Stroke malossi sport cylinder 6.5g rollers 19mm stock carb 90 main jet 1pe40qmb minarelli horizontal moving piston thanks in advance.....
Post by 190mech on Aug 15, 2019 18:52:10 GMT -5
You PM'd me asking for a good pipe for a Polini Sport kit,now it has switched to a Malossi Sport kit..ERRR,which one is on your scoot???
mattyslimz
Post by mattyslimz on Aug 15, 2019 19:06:32 GMT -5
Maybe it’s a Polossi.. Malossi bore and Polini head... Anyway I’d say an Yasuni R, S6 pro replica, or even an NCY pipe makes good gains. Stay away from those “Fly” pipes that are all over EBay. This all of course is pertaining to the big bore kit your using. It IS an Malossi sport 70 after all isn’t it?
Post by matlock on Aug 16, 2019 10:12:26 GMT -5
im sorry its a malossi sport 70cc i just checked again malossi
Post by matlock on Aug 16, 2019 10:13:41 GMT -5
Post by 190mech on Aug 17, 2019 5:40:59 GMT -5
Port map I found looked like a pretty mild cylinder,so here are the pipes that will likely work well; (1) Yasuni R (2) Leo Vince ZX (3) TechniGas Next R
Post by matlock on Aug 17, 2019 19:09:52 GMT -5
Port map I found looked like a pretty mild cylinder,so here are the pipes that will likely work well; (1) Yasuni R (2) Leo Vince ZX (3) TechniGas Next R port map mild cylinder what u mean mech?
Post by 190mech on Aug 17, 2019 19:26:20 GMT -5
Post by aeroxbud on Aug 17, 2019 19:46:03 GMT -5
It's not a high rev cylinder like stated above. The Yasuni R would be my number one choice. But all of the mentioned pipes would work well. The Yasuni Z would also work well, and is usually a little cheaper if budget is tight.
Post by repherence2 on Aug 28, 2019 21:28:07 GMT -5
...or raise the exhaust port roof a tad and run a yasuni c16. or raise it even further and run a c20.
