love2ride1111
Post by love2ride1111 on Aug 21, 2019 15:36:09 GMT -5
I haven't.
Post by 190mech on Aug 21, 2019 17:21:31 GMT -5
If you are working with the TD spring,why not pop the cover off and pull the pins,clean and grease it all,reassemble and try again???
love2ride1111
Post by love2ride1111 on Aug 21, 2019 18:28:42 GMT -5
Yea I will, I had it apart but I figured I'd wait till the springs come to do that. .
love2ride1111
Post by love2ride1111 on Aug 22, 2019 0:21:57 GMT -5
Can someone tell me can we use a 1500k Contra spring with 2k clutch springs or does that screw stuff up ?
Post by 190mech on Aug 22, 2019 1:35:29 GMT -5
That'll work fine..
love2ride1111
Post by love2ride1111 on Aug 23, 2019 10:16:37 GMT -5
Can a torque driver pulley go bad ?
Post by harleyracer59 on Aug 24, 2019 3:30:47 GMT -5
yes it can. besides the bearings that ride on the trans shaft, the slots that it slides open and close can get sloppy and which can cause binding. have you done a plug chop yet? I still think its running rich with a small 10%+- chance it could be lean. If the cvt doesn't fix your issue, check your plug. im guessing its running rich and youll have to drop a size or 2 on the main jet.
love2ride1111
Post by love2ride1111 on Aug 24, 2019 15:41:24 GMT -5
I now must have multiple issues. Performance just getting worse and worse over the last few days. I had put a new carb on a few months ago and it started right up consistently after i put the correct 90 size jet in, before it would not start because too lean, i figured that out when i covered the intake with a rag and it would start every time. Now all of sudden it wwont start again. I pulled the plug and it definitely shows hot. Ughhhh 😫. Thr only thing that comes to mind is that last week when. I had scooter all apart i saw a clamp to the carb was sitting to high on thr hose so i moved it back over the nipple and i noticed a strong indentation on the hose. Perhaps it cut it open and is allowing air in. ? It will not start normal, high idle, and extreme poor performance It will be a miracle if it is running properly by the time thr scooter meetup is.
Post by ThaiGyro on Aug 26, 2019 23:03:31 GMT -5
love2ride1111
Post by love2ride1111 on Aug 27, 2019 18:22:54 GMT -5
I already have brand new Polini. Anyway check out this plug color, is this just right or lean? Apparently i thought i could post a photo. Dont see any button.
Post by harleyracer59 on Aug 27, 2019 21:04:42 GMT -5
go to descktop version at bottom of page. im not sure how to post pics in the mobile version either
love2ride1111
Post by love2ride1111 on Aug 28, 2019 12:37:53 GMT -5
Cool thanks for your help. Anyone have opinions on plug photo. Just right or lean.?
Post by harleyracer59 on Aug 28, 2019 15:12:33 GMT -5
that's lean and oil fouled. what # plug is it? heat rage looks wrong too
love2ride1111
Post by love2ride1111 on Aug 30, 2019 15:51:09 GMT -5
I will repost a new pic of plug it actually looks great and the oil drip you saw i think was not oil fouled, thpugh i do add a lot of extra to the tank fot precautions. The plug is a NGK BR8HS. Besides thr problem with the torque pulley iys running very nice. I had everything apart again amd back together. There may be an intermittent air leak. I taped around where i thought one may be. But it stsrts beautiful, idles and is really ripping when thr torque pulley doesn't hang up. I dremelled insode the rear bell and the clutch and its connecting/ grabbing very good.
