Post by walleye1963 on Aug 22, 2019 5:38:34 GMT -5
hi guys.i got a taotao evo50 with a 72 bbk 90 main jet tryed 80 85 90 95 but with ever one when i take off it will hesatat 2 times befor it starts to take off. im thinking its the pilot jet checked it but theres no number.could this be the problem? and i have a open filter on also if it is the pilot can you tell me what size or sizes i should order any help would be great thank you.
Post by FrankenMech on Aug 22, 2019 17:09:25 GMT -5
Why don't you just buy a 'performance' carb meant to be used with an open filter rather than a 'stock replacement' carb meant to be used with a stock airbox?
carb help
Aug 22, 2019 20:58:24 GMT -5
via mobile
Post by oldunclestevo on Aug 22, 2019 20:58:24 GMT -5
Have you tried adjusting the needle? You shouldn't need to mess with the pilot jet. I will say i had issues like this with cheaper carbs until i finally bought a naraku. I wanted a keihin but scrappydog got bought out by some fools that didnt redirect the website or fill my order until i kept digging after about a month. (Random rant)
Post by walleye1963 on Aug 22, 2019 23:57:20 GMT -5
Why don't you just buy a 'performance' carb meant to be used with an open filter rather than a 'stock replacement' carb meant to be used with a stock airbox? ok so were do i get a performance carb at?
Post by FrankenMech on Aug 23, 2019 1:45:13 GMT -5
Many people sell them. They are specified as performance rather than stock replacement.
Post by GrumpyUnk on Aug 23, 2019 8:16:07 GMT -5
Hesitation can be caused by a momentary 'lean' condition when the throttle is opened. Some carbs have an auxiliary squirter called the 'accelerator pump' that shoots a spray of liquid fuel into the inlet to the venturi. It is operated by a flat metal tab that moves when the throttle control is moved to open the throttle. The movement depresses a shaft that causes the squirt. If there's too much play, or delay, the accelerator pump may not operate or may operate a bit too late. Check your linkage. tom
