Post by vade420 on Aug 23, 2019 16:12:22 GMT -5
Which moped is comparable so I can look for parts
Post by 90GTVert on Aug 27, 2019 8:51:56 GMT -5
It's a lot like the 1E40QMB, but with some differences. Really, all of the Chinese horizontal Minarelli clones have things you need to look out for when buying parts. Here's some info on the FM. 49ccscoot.proboards.com/thread/1258You said in another thread that you need an input shaft. Primary drive shaft I assume. That's the one that the rear pulley rides on. I don't know if they come with different gear ratios, but if you have the 13/52 primary gearing then you could get one from an E-Ton Beamer. They have a special feature. A nub on the end that interacts with an extra bearing in the small gearbox half. If your gearbox is pre-bored for a bearing there, it should take a 6200 bearing, and then it gives the shaft additional support. I use that setup on my scooters and it beefs up the gearbox a bit. Here are E-Ton parts for the gearbox. get2itparts.com/index.php?main_page=index&cPath=135089_119229_119723If that doesn't work, check : www.partsforchinesescooters.com
