Post by magoconnor on Aug 23, 2019 17:40:47 GMT -5
Hello. So Im wiring up my 4 pin rectifier : www.racing-planet.de/regulator-naraku-high-output-ac-dc-4-pin-p-101911-1.htmlThe wiring is showned on the secound picture. 1. pin : goes to the battery (dc) 2. pin : Is the yellow wire coming from the stator. Im getting little over 14 volts at idle. 3. pin : is the white wire coming from the stator. Im getting little over 17 volts at idle. 4. pin : Ground. My problem is that I only get 6 volts from the 1.pin (wire going to the battery (dc). I have tried several rectifer's with the same result. Can any body explain to me what im doing wrong?
Post by 90GTVert on Aug 27, 2019 9:25:28 GMT -5
Have you tried measuring voltage at the battery with it all connected when the scooter is running to see what it's doing there?
