Post by zanegrey on Aug 24, 2019 21:08:52 GMT -5
I have a 08 keeway venus . it is 50 cc and 2 stroke.
I was wondering if any one knew about the throttle cable splitter .
a second cable goes to a mechanism mounted outside the casing and below the stator ..
I am thinking it is an advance for the timing .
it is connected to throttle response...
any help would be greatly appreciated...
thank you
Post by ryan_ott on Aug 24, 2019 21:21:34 GMT -5
That split cable operates the oil injection pump located behind the flywheel.
WELCOME!!!
Post by zanegrey on Aug 24, 2019 21:24:07 GMT -5
thank you so very much. so then it might be alright to by pass it till I get the correct cable as long as I premix the gas...?
Post by ryan_ott on Aug 24, 2019 21:37:13 GMT -5
Post by zanegrey on Aug 24, 2019 21:40:43 GMT -5
what about just keeping the reservoir empty...
I also am all about keeping things stock if I can. this bike was a find so I will just be putting it back in order and sending it on its way. for me I the fun is working on them...
Post by ryan_ott on Aug 24, 2019 21:51:39 GMT -5
If you run the pump empty it could be damaged. The injection oil is what lubes the workings of the pump itself.
Post by zanegrey on Aug 24, 2019 21:55:08 GMT -5
I have ordered the cable so I will just wait for it.
no sense In tearing anything up for a ride or 2 around the yard.
thank you …
Post by zanegrey on Sept 9, 2019 16:44:20 GMT -5
Got my cable installed.. Carb is really dirty. Went over it once but till have to again. the rings may gone or maybe even the crank bearings.. Sounds rough ... And not idling correctly.
Will report after I redo the carb.
Does n/e 1 know if this the same engine as the sense...?
Post by 190mech on Sept 9, 2019 16:55:32 GMT -5
Keyway is a horizontal Minarelli (Chinarelli),Hyosung Sense is a one off version of the Morini engine,waaay different..Keyway parts,repairs and mods are easy and cheap!!
Post by zanegrey on Sept 9, 2019 17:06:50 GMT -5
ty.. I have not really looked for parts yet but if the rings and cylinder are messed up I will be looing for a big bore kit...
