Post by chris79 on Aug 25, 2019 6:06:18 GMT -5
Hi I have a Yamaha jog which I have changed the exhaust and took the snorkel off air box and changed jet size a tiny bit. And now when on full throttle it seems to make a pinking sound and won’t get to top speed. Any idea what I’ve done wrong thanks.
Post by aeroxbud on Aug 25, 2019 6:11:07 GMT -5
As a guess you might need to go bigger on the main jet.
Post by chris79 on Aug 25, 2019 6:38:29 GMT -5
As a guess you might need to go bigger on the main jet. cheers mate I was going to go up another size as it did seem to be running low on fuel.
Post by FrankenMech on Aug 25, 2019 10:37:18 GMT -5
Hi I have a Yamaha jog which I have changed the exhaust and took the snorkel off air box and changed jet size a tiny bit. And now when on full throttle it seems to make a pinking sound and won’t get to top speed. Any idea what I’ve done wrong thanks. That sound is your engine trying to destroy itself.
Post by christopher on Aug 25, 2019 12:00:00 GMT -5
How much is a tiny bit? When I opened up the air box on my 2 stroke, I went up 10% as a starting point and I'm not running rich yet. Better to foul out a plug running rich then destroy your motor running lean.
Post by chris79 on Aug 26, 2019 3:32:57 GMT -5
How much is a tiny bit? When I opened up the air box on my 2 stroke, I went up 10% as a starting point and I'm not running rich yet. Better to foul out a plug running rich then destroy your motor running lean. it had a 70 jet in it and I just went up to 80.
Post by christopher on Aug 26, 2019 5:31:19 GMT -5
Did you try putting the snorkel back in and see what happens. That should make it run richer if you are running lean.
Post by chris79 on Aug 26, 2019 20:20:22 GMT -5
Did you try putting the snorkel back in and see what happens. That should make it run richer if you are running lean. that was the plan but I seem to have miss placed it so going to try another air box see if that helps.
Post by christopher on Aug 27, 2019 5:39:53 GMT -5
Put tape over part of the hole.
Post by 90GTVert on Aug 27, 2019 8:47:59 GMT -5
Try different jets and see what happens. Do some tuning passes and record data with each to find out what jet works best.
