Post by magoconnor on Sept 5, 2019 22:33:13 GMT -5
Post by Raizer on Sept 6, 2019 2:20:43 GMT -5
I found it way too restrictive on my Gyro, running a Uni pod now.
Post by magoconnor on Sept 6, 2019 23:24:06 GMT -5
Do you think it can be modified to deliver more air? Also how does the filter work? is it one big foam filter inside?
Bgm Also makes one "twin slot air box" i think its name is. bgm AirBox has an inlet area of approx. 1500 mm2
Could this work better?
Post by magoconnor on Sept 7, 2019 0:01:25 GMT -5
It seems like the bgm version is a bit larger. From the description of varies websites:
motoforce box: 175mm Length 90mm wide bgm box : 240mm length 90mm wide.
Maybe it can deliver more air?
in the bgm description it says that it can deliver air up to a 25mm carb. I wonder if its true..
Post by Raizer on Sept 7, 2019 2:42:43 GMT -5
It's got 2 really small but thick foam discs in the ends of the inlet tubes.
Post by oldgeek on Sept 7, 2019 6:42:47 GMT -5
I also found it to be surprisingly restrictive on my 2T
Post by magoconnor on Sept 7, 2019 16:28:55 GMT -5
Post by oldgeek on Sept 7, 2019 16:56:29 GMT -5
I also tried those, they helped but I opted for something else. BTW sometimes the little foam buttons get sucked out of those and into your carb or motor.
Post by magoconnor on Sept 7, 2019 17:47:13 GMT -5
Uhm.. that dosent sound too good. Maybe there is a way to secure them better, at least so they dont get sucked in carb. Was 3 extra inlets enough? How was the sound with the box install? Is there any where, you can send me some measurements on it? It would be fun to compare it, side by side with the bgm box www.scooter-center.com/en/airbox-twin-slot-bgm-pro-black-28/35/50mm-bgm4200I think the bgm one is bigger, but who knows alot of lies can be found on the web..
Post by aeroxbud on Sept 7, 2019 17:56:32 GMT -5
Uhm.. that dosent sound too good. Maybe there is a way to secure them better, at least so they dont get sucked in carb. Was 3 extra inlets enough? How was the sound with the box install? Is there any where, you can send me some measurements on it? It would be fun to compare it, side by side with the bgm box www.scooter-center.com/en/airbox-twin-slot-bgm-pro-black-28/35/50mm-bgm4200I think the bgm one is bigger, but who knows alot of lies can be found on the web.. The motoforce Air box is Length= 175mm, diameter=90mm. So same diameter, but bgm is longer.
Post by magoconnor on Sept 7, 2019 18:44:04 GMT -5
I wonder if the bgm is only longer because they include the rubber mounting hose in the entire measurement. Box + hose.
Or if its just longer. Maybe it can deliver more air, right out of the box? It says in the bgm description that it has an inlet area of approx. 1500 mm2
I wonder if its that same as the motoforce?
Post by magoconnor on Sept 7, 2019 18:51:31 GMT -5
Post by aeroxbud on Sept 7, 2019 18:57:44 GMT -5
It looks so similar. I would be surprised if it's not the same product.
Post by magoconnor on Sept 8, 2019 8:57:36 GMT -5
Do you know if its possible to change out the foam ? If so, Maybe the foam the box comes with are to restrictive, and can be change out for some double layer polini foam.
Post by aeroxbud on Sept 8, 2019 13:45:56 GMT -5
Pedparts says of the motoforce filter "The filter material is sponge which you can take out and wash or treat with air filter oil if required." So you could change it.
