Post by markogarelli on Sept 16, 2019 13:03:34 GMT -5
I changed the rollers on my 50cc, i put everything back like it was, but now there is strange noise coming from the cvt, it runs pefect but at idle there is the noise
Post by markogarelli on Sept 16, 2019 13:06:25 GMT -5
Post by dexameth on Sept 16, 2019 13:44:32 GMT -5
Sounds to me like you forgot to put the back-plate slide tabs back on, so now the variator it rattling/bouncing back and forth. This can KILL the variator. Pull it apart and inspect.
Rune 75
Post by Rune 75 on Sept 16, 2019 13:47:22 GMT -5
I changed the rollers on my 50cc, i put everything back like it was, but now there is strange noise coming from the cvt, it runs pefect but at idle there is the noise Pull it apart again, something is most likely missing or put together wrong.
Rune 75
Post by Rune 75 on Sept 16, 2019 13:48:05 GMT -5
Sounds to me like you forgot to put the back-plate slide tabs back on, so now the variator it rattling/bouncing back and forth. This can KILL the variator. Pull it apart and inspect. I second this.
Post by markogarelli on Sept 17, 2019 6:12:09 GMT -5
Thanks to everyone, i thought i had everything put togheter as it was, turns out i lost a washer, thats all it was.
