Post by 12enric on Sept 24, 2019 17:59:23 GMT -5
Hi, I recently bought a Benelli Quattronove, at the moment I am trying to understand what it has, today I unasembled the bike and I found the following, It has a 72CC cylinder but I don't know which brand it is, if any one knows I would really appreciate the help in identification it, the second is the carb, I think that the carb I have is the following one " www.modcycles.com/mm5/merchant.mvc?Screen=PROD&Product_Code=MGMO1143_tk " I uploaded a picture ant there you can read the brand, on the carb is written JAPAN, so I think is a 19 mm carb, I thought that with the 72CC ant that carb I would be able to remove the air filter snorkel, but when I did when I was accelerating the bike was running to lean, so I might have to upgrade the jets of the carb, do you know which jets are compatible with the carb?? which jet size do you recommend me for the main and the small one? thank you so much, any ideas you have will be really appreciated.
Post by matlock on Sept 26, 2019 12:12:52 GMT -5
it takes the same jet size as a 1pe40qmb engine
