Post by matlock on Sept 25, 2019 16:13:40 GMT -5
please tell me corrdct way to install the dr pulley rollers insaw a video once but cant find it again they are all slider videos one side of dr pulley roller hass a smaller hole and the other side is normal i know there was a certain way please help wkth video or good explanation
Post by fugaziiv on Sept 25, 2019 16:17:41 GMT -5
We made a video just for this a little while ago.
Matt
Post by matlock on Sept 25, 2019 16:20:38 GMT -5
like i said not slider i need roller install one side has smaller hole not sliders
Post by fugaziiv on Sept 25, 2019 16:23:45 GMT -5
like i said not slider i need roller install one side has smaller hole not sliders Oh sorry. Rollers... it doesn't really matter actually. Just put them all in to the left or right, and you're good to go. Matt
Post by matlock on Sept 25, 2019 16:29:50 GMT -5
no then dr pulley rollers are different one end is sealed with small hole i need the proper direction please
Rune 75
Post by Rune 75 on Sept 25, 2019 16:30:32 GMT -5
Big hole pointing the same way as the variator turns. It's for preventing the brass core from sliding out under quick increase in revs. Well that's the theory, don't think it will happen.
Post by matlock on Sept 25, 2019 16:39:09 GMT -5
i need a picture or some better explanation
Post by fugaziiv on Sept 25, 2019 16:40:18 GMT -5
Big hole pointing the same way as the variator turns. It's for preventing the brass core from sliding out under quick increase in revs. Well that's the theory, don't think it will happen. Yeah, but in reality it doesn't matter. If you wear those rollers down enough to lose the core, they're in bad enough shape that they shouldn't be in there in the first place. Matt
Post by fugaziiv on Sept 25, 2019 16:42:44 GMT -5
no then dr pulley rollers are different one end is sealed with small hole i need the proper direction please Yes, I know. I'm the only US importer for Dr. Pulley rollers. If you must have a direction, watch the video I linked. Even though they are sliders and not rollers, they still have an open side and closed side and so directionally it'll be the same as in the video for your rollers. Matt
Rune 75
Post by Rune 75 on Sept 25, 2019 16:54:41 GMT -5
Big hole pointing the same way as the variator turns. It's for preventing the brass core from sliding out under quick increase in revs. Well that's the theory, don't think it will happen. Yeah, but in reality it doesn't matter. If you wear those rollers down enough to lose the core, they're in bad enough shape that they shouldn't be in there in the first place. Matt I know. That's why I said in theory. Just trying to give matlock some peace of mind. . He obviously wants his rollers the right way.
