Post by paulmars on Sept 29, 2019 11:32:52 GMT -5
regularly driven 2-4 times a week.
wolf rx-50 with 49cc gy6 qmb139 engine.
battery 12.x volts.
full voltage at the starter push button.
no voltage at the starter when starter push button is pressed.
ideas?
tks, paul
Rune 75
Post by Rune 75 on Sept 29, 2019 11:41:53 GMT -5
Does it click when you hit the starter button ?
Post by tortoise2 on Sept 29, 2019 12:19:34 GMT -5
Post by SMALL CC TEK on Sept 29, 2019 12:24:12 GMT -5
Check the fuse ?
Post by fortyeight on Oct 1, 2019 15:22:45 GMT -5
side stand switch ,cut out switch
Post by paulmars on Oct 1, 2019 19:36:22 GMT -5
Post by paulmars on Oct 2, 2019 20:08:08 GMT -5
Tks. Batt voltage is 12.8
Batt plus to one red on relay is 12.8. the other red on relay is zero volts.
That same other red on relay to starter is 2.2 ohms.
Confusing is that same other red on relay to engine gnd is 5.8 ohms.
Ur thoughts?
Tks, paul
Post by paulmars on Oct 3, 2019 11:44:52 GMT -5
starter btn bad
Post by paulmars on Oct 10, 2019 16:50:30 GMT -5
It worked for a few days with new switch, now its dead again. Now both sides of the start switch have 12.7 volts even with key removed and brake not engaged. Switch is fine.
Ideas? tks, paul
