Post by fitzgr8 on Oct 5, 2019 13:15:35 GMT -5
I'm installing a BBK with a Delorto carb and I need to know where to purchase the correct cables. Can someone please direct me to what I need?
Thanks
Post by Zino on Oct 5, 2019 16:00:05 GMT -5
If you have a pre bug no bug eye headlights . You are swapping a smaller manual choke dellorto for a larger one . You already have the right cables and just need to adjust them .
Post by fitzgr8 on Oct 6, 2019 7:57:31 GMT -5
The stock cables are to short to work with the Delorto carb. Meaning there is not enough cable to hook up the slide and choke slide.
Post by Zino on Oct 6, 2019 14:31:21 GMT -5
If you are in the USA or Canada you could have your parts by the end of the week . Scooterswapshop out of Portland Oregon, Scootertuning out of Canada I have bought a good share of parts from both . Make a call to either . They both look like they are in stock by there websites .
Post by geoffh on Oct 6, 2019 15:12:11 GMT -5
Fitz,you may have to rethink your cable routing,there are lots of people on here that have swapped carbs and loads of mods,the cable never seems to be an issue I can only remember one guy chopping the cable,if you can,t work it out a visit to your local cycle shop might help,keep us posted.
Post by fitzgr8 on Oct 24, 2019 14:54:39 GMT -5
Ok so now that I have the cables sorted out i'm trying to tune this Zuma. Does anyone know of a good source for the 5mm Dellorto main jet kits on the 19mm carb?
Thanks
Post by Zino on Oct 24, 2019 18:20:25 GMT -5
