Post by scooternub on Oct 8, 2019 8:10:27 GMT -5
Post by geoffh on Oct 8, 2019 15:01:51 GMT -5
In short yes any in-line filter will do,just take the old one with you to match up,I don't,t think that will cure your problem sounds like an adjustment or repair is required.
Post by scooternub on Oct 8, 2019 15:38:22 GMT -5
It gets me a to b for now. I know no one to work on it plus no money for repair or upgrade. fuel filter not bad idea to try. What do I use to block gas from coming out before the filter to match up?
Post by aeroxbud on Oct 9, 2019 14:27:54 GMT -5
If you have a vacuum line out of the fuel petcock. You should not get a lot of fuel come out. It only lets fuel out when the engine is turning. Just have a paper towel to catch what comes out of the line. It won't be loads.
