Post by smooch on Oct 10, 2019 10:51:27 GMT -5
I have a 50cc Taotao 1p39qmb. I put a BBK 50mm piston big valve heads a KeiHin 20mm carb or CVK. I put 6g rollers in the cvt. No rev cdi and 49/17 final. It was doing about 50mph now I barely get 40mph. It starts very hard so I adjusted the valves. Still starting hard. Do you think my timing chain jumped a tooth? Also has a idleing problem when started. I don't know if that has any thing to do with the fuel enricher. I believe I have the fuel to air mixture correct?
Post by scooterted on Oct 10, 2019 13:08:52 GMT -5
This isnt really the correct section for troubleshooting. The 4 stroke troubleshooting section would probably be more helpful.
Its probably one problem causing all those things. Im thinking a compression loss. But it could be several things.
If it were me, I would: Inspect/change the spark plug. Clean the air filter. Do a compression test. Check camshaft alignment. Inspect cvt while i was at it. Clean carb while I was at it.
Rune 75
Post by Rune 75 on Oct 10, 2019 13:31:27 GMT -5
If you can post a video of it idleing and you revving it that my help hearing what the problem is.
