Post by matlock on Oct 11, 2019 20:37:35 GMT -5
Post by matlock on Oct 11, 2019 20:39:11 GMT -5
if the cdi is restricted to 6600 rpm can anyone please help me find the correct cdi i would neeed that is not restricted no rev limit preferably thank you
Post by matlock on Oct 11, 2019 21:22:06 GMT -5
Post by 190mech on Oct 11, 2019 21:30:23 GMT -5
Post by matlock on Oct 12, 2019 9:36:46 GMT -5
you think i can expect a big difference wih the cdi if im only hitting 6600 and doing 44mph acell ect i have 70cc bbk malossi yasuni r pipe and 4 gram rollers
Post by christopher on Oct 12, 2019 9:56:54 GMT -5
If your max rpm is truly 6600 I don't think your getting into the power band for the chambered pipe or the cylinder. My Tecnigas Next R pipe doesn't get started into its torque band until 7500 rpm I can feel it. According to these graphs you picked high revving parts and aren't getting into your power band until 8500 rpm and continues to 10,000 rpm. What does your tachometer say your max rpm is? At this point it sounds more like your guessing than measuring. If your guessing get a tachometer so you know, helps with tuning also. www.pedparts.co.uk/blog/sports-exhaust-testing-50cc-and-70cc-sports-mopeds-part-two
Post by christopher on Oct 12, 2019 10:20:41 GMT -5
Post by matlock on Oct 12, 2019 12:47:25 GMT -5
i dont have a tach i just noticed the stock cdi says says 6600 rpm cdi i ordered a race cdi i will be getting a tach next month the bike goes real fast though from 10 mph up until 45
Post by matlock on Oct 18, 2019 12:32:10 GMT -5
well my new cdi finally came it is no difference at all its a fully unrestricted cdi and bike still goes 47 47 mph i have stock variator how are these other people doing 55 60 mph? is the variator gonna make that big a difference without the yasuni pipe my speed was 38 39 with yasuni its now 47 so maybe with malossi multivar i will game 8 mph and be at 55 mph?
Post by Zino on Oct 18, 2019 17:57:30 GMT -5
How to increase speeds high rpms with power Your pipe pushes higher rpm with power with your bbk
The 2nd way is to increase the gear ratio .
Swap in bigger final gears ,Larger tires and a larger Variator all accomplish this
I noticed 3-4 mph extra from the malossi multi var variator ,Gears gave me 8 mph tires were 1-2 mph
