Post by SMALL CC TEK on Oct 19, 2019 10:38:39 GMT -5
The serious issue is the preheating of the cylinder if you weld or braze it could ruin the cylinder .
Post by harleyracer59 on Oct 19, 2019 17:41:55 GMT -5
The serious issue is the preheating of the cylinder if you weld or braze it could ruin the cylinder . ive had good luck preheating cast parts in the oven before brazing or welding. the preheat also helps pull the oil from porous cast aluminum, which can also cause issues when welding
Post by pitobread on Oct 20, 2019 0:50:15 GMT -5
yeah if you get it warm and use a high nickel rod your good.
but brazing would be my go to for that repair.
