Post by jessemiller8781 on Oct 17, 2019 13:32:31 GMT -5
Im pretty sure its an air issue but i put a Mallossi 72cc BBK and style pro(dellorto clone) 19mm carb leo vince Zx exhaust exhaust and tuner pod air filter... The bbk most recent mod and for some reason the reeds for mallossi dont match the holes on the kymco reed valves it over laps but doesnt match exactly.. Is it possible this may be my problem when i blow air in w air compressor fires right up only thing i can tell it may be.. If so what can i do to fix the problem?
Post by aeroxbud on Oct 17, 2019 14:26:47 GMT -5
You don't have to use those reeds. Perhaps put the old ones back on. See if it improves.
Post by 90GTVert on Oct 17, 2019 15:00:45 GMT -5
If there's any doubt about the reeds and their ability to seal, maybe try stock as suggested above. Not sure what you mean about blowing in air with an air compressor to make the engine fire up. Where are you blowing air in?
