liambelgium
Scoot Junior
Chinese (keeway) 50cc 1E40QMB 2stroke
Post by liambelgium on Oct 21, 2019 12:52:48 GMT -5
My scooter doesn't take of at the same rpm it starts high then lowers en then climbs back up anyone any ideas to fix this ?
Post by dexameth on Oct 21, 2019 13:46:11 GMT -5
That is the action of stock torque drivers and the angle of which they open and close. They are designed to function that way. It basically gives you good high-rev power to take off, then settles to a lower, more fuel efficient RPM. I like to swap them out with straight-groove torque drivers like this one: SSP-G Torque DriverHere's a video how to install them:
liambelgium
Scoot Junior
Post by liambelgium on Oct 21, 2019 15:23:29 GMT -5
Would lighter roller weights also help ?
liambelgium
Scoot Junior
Post by liambelgium on Oct 21, 2019 15:25:35 GMT -5
And does an aftermarket air filter give you extra performance ?
Post by dexameth on Oct 21, 2019 15:28:00 GMT -5
Would lighter roller weights also help ? Possibly, but the actions of the revving up and then back down will still be the same.
Post by dexameth on Oct 21, 2019 15:28:31 GMT -5
And does an aftermarket air filter give you extra performance ? As long as you have the correct jetting (most of the time you need to upjet to match the extra amount of air being introduced into the engine).
