Sum-azn-kid
Post by Sum-azn-kid on Nov 14, 2019 3:04:29 GMT -5
Stator that came off my aprilia motor has 4 wires. But looking online most bikes have 5-6 wires. Anybody know why the other stators have added wires? Also what are those other wires for? Thanks
Post by aeroxbud on Nov 14, 2019 4:07:45 GMT -5
I know Yamaha changed their stator in 04. The early version has 4 wires. The later ones (6 wires) have twice as many poles.
Post by ThomasTPFL on Nov 18, 2019 10:26:25 GMT -5
Is the original a DC CDI set up? They have a different harness since they don't have a separate power coil for the ignition.
Sum-azn-kid
Post by Sum-azn-kid on Nov 19, 2019 4:04:47 GMT -5
Is the original a DC CDI set up? They have a different harness since they don't have a separate power coil for the ignition. I only have the motor Im doing a motor swap into a different chassis that didnt have a minarelli motor. So Im debating which stator to buy (most common) seems like 5-6 wire is the most common
Post by dexameth on Nov 20, 2019 9:53:54 GMT -5
Find out what the wire harness is of the new chassis, and get a matching stator for it. You'll have less headaches down the road.
Sum-azn-kid
Post by Sum-azn-kid on Nov 25, 2019 2:48:16 GMT -5
Wiring on the scooter is like dio/ gy6. Ill probably use a zuma harness or jog copy one
Sum-azn-kid
Post by Sum-azn-kid on Dec 3, 2019 15:23:05 GMT -5
Anybody here ever run the mvt millenium stator and cdi kit? Not looking for a inner rotor kit just something better then stock and new 😅
Post by Kenho21 on Dec 3, 2019 15:26:28 GMT -5
I’ve been looking at that or the hoca (or ssp-g if that’s what it’s called now) that parts for scooters sells. Really just depends on what kind of power each puts out, but I wanna get one too. Definitely interested in this topic. Maybe we can each buy one and do some testing or something.
Sum-azn-kid
Post by Sum-azn-kid on Dec 4, 2019 4:03:43 GMT -5
I’ve been looking at that or the hoca (or ssp-g if that’s what it’s called now) that parts for scooters sells. Really just depends on what kind of power each puts out, but I wanna get one too. Definitely interested in this topic. Maybe we can each buy one and do some testing or something. It will be a while beforw I put funds towards making a runing motor. Im focusing on the chassis and wheel first. I just have a bare aprilia case at the moment. Also need to work on the wire harness. Its a long term project
Post by Kenho21 on Dec 4, 2019 10:12:04 GMT -5
Well maybe I'll find the answer for us then. I'll try to keep this thread in mind. The last two major upgrades I have in mind that I haven't purchased yet are the lightened flywheel and an over range. Neither are cheap... especially those damn over ranges.
Sum-azn-kid
Post by Sum-azn-kid on Dec 6, 2019 2:42:02 GMT -5
I plan on getting an over range kit too 😅 ill keep an eye on your build thread
Post by Kenho21 on Dec 6, 2019 7:27:37 GMT -5
I plan on getting an over range kit too 😅 ill keep an eye on your build thread Which over range are you planning on?
Sum-azn-kid
Post by Sum-azn-kid on Dec 6, 2019 23:55:29 GMT -5
Ive always been a polini fan after runing the corsa and comparing it to malossi's mhr rep. And cast iron bores. Also had some bad luck with a BNIB malossi full circle crank for my dio. So im not gonna gamble my $ on their OR kit. I like stage 6 parts too but they are nvr in stock state side so that leaves polini.
Post by repherence2 on Dec 10, 2019 20:19:18 GMT -5
Ive always been a polini fan after runing the corsa and comparing it to malossi's mhr rep. And cast iron bores. Also had some bad luck with a BNIB malossi full circle crank for my dio. So im not gonna gamble my $ on their OR kit. I like stage 6 parts too but they are nvr in stock state side so that leaves polini. Oldgeek recently ran into that same crank issue too.
