Post by scooterted on Nov 14, 2019 9:42:23 GMT -5
More specifically, what do you do with the throttle after killing spark?
What i mean is, you do your pull, kill spark, stop quickly (because a scoots clutch stays engaged until you slow down), do you allow the throttle to close? Or keep it open until the engine stops turning?
Post by jackrides on Nov 14, 2019 10:29:18 GMT -5
Close throttle. Won't alter color, but why not have a dryer plug.
Post by 90GTVert on Nov 14, 2019 13:33:30 GMT -5
Shut off engine and shut throttle. Brake so the engine actually stops and then coast into the driveway. Cut plug apart to look at mixture ring.
That's all for a 2T and only when I'm otherwise unsure or lost about what it needs. For a 4T, I just go through a trial and error tuning process, recording data along the way to make a decision. They aren't volatile enough to warrant plug chops to me.
Post by Zino on Nov 14, 2019 18:13:39 GMT -5
Plug chop 101 do some wide open runs with a range of jets start biggest to smallest note top speed and any hesitation or bog on each jet. After finding a main jet that you feel has best top speed performance .
Warm up the scoot for 5 minutes or so at least until the choke shuts off with a old plug . Swap in a new plug Go wide open for about a mile or so Its where I can pull over at my buddy's shop .
Hit the kill switch and close throttle coast to a stop and swap out the plug .
Take it home saw off the threads and look for a 2 mm light smoke ring at the base of the plug to verify I'm in a safe range . When you get better at this you can use a light and a magnifying glass .
If no ring or smaller than 2 mm ring go to a bigger jet and retest.
Post by nelson on Nov 14, 2019 20:19:45 GMT -5
Wot then kill it with wot. Cut threads off in vice with hack saw
