Post by captjeff01 on Nov 16, 2019 19:54:38 GMT -5
Just purchased a 2008 Chinese scooter 150 runs well but noticed after riding a while at top speed, there is either engine oil or rear end lube on top of cvt cover, can't find where it is coming from, low mileage bike 2800 miles, any suggestions ?
Post by SMALL CC TEK on Nov 16, 2019 23:11:27 GMT -5
Make sure your vent tube on your rear end is not kinked or clogged . Your rear end could have been over filled from factory or it could be just a lose rear end drain plug .
Post by Zino on Nov 16, 2019 23:18:06 GMT -5
It also could be overflow from the fuel tank , My zuma has a vent tube that drips on the cvt if I dont connect it right.
Post by captjeff02 on Nov 17, 2019 7:07:48 GMT -5
Thanks, I just did change all fluids, I was thinking vent tube issue, will investigate this morning !!
Post by pinkscoot on Nov 17, 2019 9:22:35 GMT -5
It's probably the crankcase breather hose that usually vents to the air box. There is probably a hose or a nipple to a hose on the bottom of you air box that it's coming from.
