Post by captjeff01 on Nov 17, 2019 12:20:41 GMT -5
What are differences between the 835-20-30 and 842-20-30 it seems either will work in my longcase gy6 150
Post by Zino on Nov 17, 2019 13:28:56 GMT -5
Are they the same brand say bando or gates that is the only way to be sure they are actually different .
I have a polini belt that says it is 750 mm to the stock zuma belt at 738 mm and they have the same travel and same rolling length .
If they are the same brand you may get more belt travel on your variator and rear pulley so higher top end and better take off because you would be picking up a higher gear and lower gear.
Post by christopher on Nov 17, 2019 21:09:28 GMT -5
What are differences between the 835-20-30 and 842-20-30 it seems either will work in my longcase gy6 150 The 842mm belt is 7mm longer than a 835, all other things being equal.
