Post by coaconi on Nov 18, 2019 7:31:17 GMT -5
Can i put peugeot belt on aerox belt is 765x17,5 I need it to get belt to top of variator
Post by Zino on Nov 18, 2019 8:59:03 GMT -5
We try all different size belts . Just have to be careful hpw you big you go over stock it makes a mess Is your stock aerox belt 757 mm? How much belt travel is left on your pulleys ? Take a sharpie on both pullie's and run down the road a record the mm of sharpie left . Instead of using pie r squared Here is a shortcut . Take your stock belt and add (3 x the mm of the smallest pulley left) . That will give you a range to try you may have to add a shim for the extra width of the puegot belt
Post by coaconi on Nov 18, 2019 10:12:45 GMT -5
my stock belt is 751x16,5 and it does not want to go on top of the variator. I tried hevier rollers and it still does not go. The belt is wide enough but i think it is not long enough to go to the top On pulley it stays on top. Tried with softer spring, still same
Post by Zino on Nov 18, 2019 17:37:57 GMT -5
how many mm of travel do you have left to the outer edge of variator
Post by repherence2 on Nov 18, 2019 20:17:04 GMT -5
Are you sure your variator is even capable of the belt being able to achieve "max/full" travel?
Stock variators are limited by the roller ramps on the variator. On aftermarket variators, the ramps extend further out than the stock variator roller ramps.
Post by coaconi on Nov 19, 2019 0:56:16 GMT -5
i have polini variator it has about 8mm left to the top My top speed is 70kmh on gps which is bad i have stage 6 pro replica exhaust too
Post by Zino on Nov 19, 2019 6:47:30 GMT -5
Swap in the puegot belt and give it a try 8mm gives you alot of leeway. I was able to go up a size belt with stock rear pulley on my yamaha zuma with the polini variator . I did have to add a about mm in shims so my belt would get down low enough in the pulley
Post by aeroxbud on Nov 22, 2019 19:46:42 GMT -5
The Peugeot belt is 1mm thicker than standard. You might need to shim it out a bit to work properly.
Post by coaconi on Nov 23, 2019 11:27:13 GMT -5
i dont care about thicknes but i am scared that it is too long can it go out of range of variator and destroy everything? or to go out of pulley?
Post by aeroxbud on Nov 23, 2019 12:09:11 GMT -5
I guess its a possibility. Perhaps try it on the stand first, with the CVT cover off. You can then look and see how it performs, with little load on it.
