Post by ThaiGyro on Feb 14, 2020 8:17:11 GMT -5
freeqsee: the guys above are trying to find out what your overall tuning set is..all specs are important in two stroke tuning. The common thing to do in creating reliable tuning, is to eliminate the oil pump and mix your oil and gas in the petrol tank...it is called "pre-mix".
It must be done for every fill up, but creates a reliable mixture across the rpm range!
If you need better explanation in another language, just ask. I am good at Spanish, decent in French and German. Can get Japanese and Chinese easy...
We are here to help!
Post by freeqsee on Feb 14, 2020 11:15:42 GMT -5
Thank you so much for your help, but I solved that problem. I replaced the 17.5mm carb with the stock one(cleaned) and the problem disappeared. The scooter is completely stock, it is going to be tuned in the future.
