Post by kakio5959 on Dec 13, 2019 14:51:04 GMT -5
wats up scooter madness riders i have a dead horse question i keep asking i have a 50cc 1E40QMB engine want to bore it up any suggestions already changed da card and da coil and da air filter any suggested brand Aloha!!
Post by aeroxbud on Dec 13, 2019 15:26:14 GMT -5
Malossi, Polini, or stage 6 all make good quality kits. What are you going to use it for? Weekend toy? Daily rider?
Post by Zino on Dec 13, 2019 17:10:21 GMT -5
For a daily rider
cast iron sport kits Malossi ,Polini Stage 6 are great choices. Double the power in the whole range without having to change out the crank. This will increase top end a little but do a ton fro acceleration.
If you want more top end Then you will want to add a pipe and variator and rebalance the trans to the powerband of the pipe.
mattyslimz
Post by mattyslimz on Dec 23, 2019 18:09:52 GMT -5
I personally am a fan of Stage 6 bores. Both 70 kits from Stage 6 on my two bikes, though 2 very different bores haven’t, let me down and love to scream. A pipe will almost be mandatory after the kit especially since you have a hot coil and different carb (assuming it’s larger in size from stock).
