Post by magoconnor on Feb 23, 2020 14:41:33 GMT -5
Hello.
Anybody got some tips on how to get these things back to new like clean?
Post by 190mech on Feb 23, 2020 18:12:35 GMT -5
Sure,Replace it with a new one!When I was a young man many methods were tried and flow was still marginal,not counting the time in my life I wasted trying to save a buck...
Post by magoconnor on Feb 23, 2020 18:54:27 GMT -5
Yeah it might be the best way to go about it Is there a fuel filter you would recommend?
Post by ryan_ott on Feb 23, 2020 19:44:30 GMT -5
Look into your tank, if there is a strainer at the outlet then nothing else should be required.
Post by 90GTVert on Feb 25, 2020 9:55:43 GMT -5
I have had chunks of debris in clear housing filters before and just blown them out with air. With the ones that come apart, I will take out the element and spray it with parts cleaner, compressed air, and then reinstall. Otherwise, I just try to keep a spare handy and replace them. I've been using some aluminum filters from China with removable elements. So far so good. I used to use VisuFilters, but the prices went up. Then I tried generic knockoffs of the VisuFilter and had a couple of them crack. One of which started pouring out fuel while I was riding and left me stranded. So if you want a filter then I would suggest a trusted brand or maybe the knockoff aluminum ones. Here's one of the aluminum ones that I use after some crud in my tank (POR15 coating flaking off).
