Post by magoconnor on Feb 26, 2020 16:05:45 GMT -5
Hello again.
I have a fun question, Im hoping some of you can answear.
I have a wiring system where the cdi sits right up front, just behind the headlight and the coil is mounted not far from engine.
which means that I have to run a long wire from cdi to the coil.
Would there be any benefit in moving the cdi box closer to the coil?
Post by 190mech on Feb 26, 2020 19:54:44 GMT -5
Nope,thats the 'low tension' side,the plug wire side(high tension) should be kept as short as possible..
Post by magoconnor on Feb 26, 2020 22:04:39 GMT -5
Super, what wire gauge would you use, from cdi to coil ?
Post by 190mech on Feb 27, 2020 0:11:48 GMT -5
18 gauge is fine,,
