Post by scootin on Oct 17, 2011 23:19:50 GMT -5
Well, I feel like an idiot! I got it running. I had to hold the choke down. I was only pushing it. It runs good. Seems to smoke a lot but that could just be me(my first 2 stroke) or the oil ( amsoil 100:1)
New problem! It won't move! It seems like the belt is slipping pr something. The tire won't spin unless I rev it kinda high (again that could be just me) How much throttle are supposed to give it before it moves?
Thanks a lot for all the help guys!
Post by stepthrutuner on Oct 17, 2011 23:25:16 GMT -5
Manual choke. Push the little lever on the handle and in comes back up. Should I be holding it down? It should stay up til you move it back down it if I understand what you said. If it doesn't then you need to hold it pushed. I'm guessing the enricher mechanism is simply a cable going into a lower spot on the carb than the throttle cable and there is no intervening lever. EDIT I posted the above whilst he was making the post above mine. Glad you got it running. :thumb:
Post by 90GTVert on Oct 18, 2011 0:03:00 GMT -5
Seems to smoke a lot but that could just be me(my first 2 stroke) or the oil ( amsoil 100:1) They tend to smoke a lot at start up if you've been using 2t oil or other assembly lube. You aren't actaully using the AMSOil at 100:1 are you? I use their Sabre Professional 100:1, but mix it at 50:1. I tried 80:1 when I first got it and it wasn't slippery enough. New problem! It won't move! It seems like the belt is slipping pr something. The tire won't spin unless I rev it kinda high (again that could be just me) How much throttle are supposed to give it before it moves? The MHR should be a fairly high revving cylinder, so it may not be that unusual to need to give it a good bit of revs to get going. Check the CVT out if you have any doubt.
