Post by Lucass2T on Sept 16, 2021 4:10:07 GMT -5
Hi guys,
Im conteplating an OEM style airbox for my 70mph daily driver. I'm looking for something more or less plug and play. I used to have this overly complex and bulky airbox system, which was way impractical and needed panels to be cut up.
Airbox wise what's on the market today for Minarelli horizontal style engines which support bigger carbs/flow rates? Im looking for a unit that fits the original location and mounts to the stock tabs. I am planning on running a Dellorto 19mm PHBG on a stock intake boot (it should fit).
Post by aeroxbud on Sept 16, 2021 9:08:04 GMT -5
A lot of air boxes use the 35mm carburettor connection. And the 19mm delly is 38. That's why I brought the 17.5 Dellorto instead of the 19. If you heated the rubber up it might fit, but they are tight anyway.
Post by Lucass2T on Sept 16, 2021 10:02:33 GMT -5
What about the aerox 100 one?
Post by repherence2 on Sept 16, 2021 11:59:23 GMT -5
What about the aerox 100 one? What about the ones for ATVs like the Polaris 90 sportsman(?). Amazon got them listed for $15.99.
Post by aeroxbud on Sept 16, 2021 12:47:40 GMT -5
Didn't the aerox 100 have a 16mm carb?
Post by repherence2 on Sept 16, 2021 15:04:15 GMT -5
What about the KN Planning "large capactity" air box from webike. It says its for a BWS100.
Post by FrankenMech on Sept 17, 2021 10:09:51 GMT -5
Airbox change, plug and play,
Post by ThaiGyro on Sept 17, 2021 13:12:36 GMT -5
We have had some fun with IAME mini swift air boxes. USA prices around $40. The Mini Swift engine is a 60cc, 10 h.p. two stroke. The air box is not huge, but work very well...single inlet bell.
Post by 190mech on Sept 17, 2021 23:56:16 GMT -5
