Post by pete130 on Nov 13, 2021 0:50:52 GMT -5
Hello been a while sine I posted, im setting up a scooter with non lighting ignition, so no battery charging, I want to still run lights and everything, to be legal, im happy to set up rechargeable battery as will only ride for maybe hour at most at a time, I have clocks that just need power from battery, its just the lights, is there a way to wire up, and just have a switch under seat thanks for any input
Post by repherence2 on Nov 13, 2021 9:59:22 GMT -5
Sure it is possible. You could even run it off of a LiPo R/C battery. You would probably need a 3S battery to be near 12 volts. Them LiPo's have some major capacity. Just make sure you install a fuse/circuit breaker in case of any shorts. liPo fires are no bueno.
Post by pete130 on Dec 22, 2021 1:11:56 GMT -5
Sure it is possible. You could even run it off of a LiPo R/C battery. You would probably need a 3S battery to be near 12 volts. Them LiPo's have some major capacity. Just make sure you install a fuse/circuit breaker in case of any shorts. liPo fires are no bueno. I ended up getting 2x 12v lithium batteries 1 for water pump and heat controler other for lights, have led head lights, and not sure if ill get led tail an blinkers, will see what sort of time I get out of them first, I was thinking of just running power to stater plug and have a switch for on and off, gets around a few problems, but im starting to think there's to much wire thats not needed and relays taking up room, so not sure witch way to go would live to just re wire to what I need but I still want key cut off to power and use straring lock
