Post by vikingsmn86 on Nov 14, 2022 10:00:09 GMT -5
I need a new battery for my 2021 tao tao VIP, any suggestions which1 is best
Post by mikescoots on Nov 21, 2022 10:17:22 GMT -5
If that's ALL you need for a Tao Tao, ANY battery will do.
Post by FrankenMech on Nov 21, 2022 13:31:35 GMT -5
Try a Sealed Lead Acid (SLA) like the ones used in computer back up supplies etc. They work even better than the wet cell batteries most scoots use and they are cheaper. You will have to change the battery connectors though.
pili
Post by pili on Nov 21, 2022 20:54:56 GMT -5
I went with an Anti Gravity lithium battery. As light as our scooters are, I figure the battery is a sizeable percentage of the weight. Feels like an empty battery shell lol. Not cheap, but I use them in my motorcycles with no cranking problems ever.
Post by FrankenMech on Nov 21, 2022 23:38:36 GMT -5
If you are worried about the weight differences of battery systems just take a healthy dump before you go for a ride or skip that big lunch.
pili
Post by pili on Nov 22, 2022 8:12:28 GMT -5
If you are worried about the weight differences of battery systems just take a healthy dump before you go for a ride or skip that big lunch. Watching your weight and cutting weight on the scoot are both good things; why not do both?
Post by jackrides on Jun 26, 2023 9:34:58 GMT -5
Anyone have good thoughts on how to safely replace a normal (lead acid) battery with a lithium one? Is there a circut board that controls the incoming carging current from the regulator? Or?
