Post by milly on Jan 29, 2023 5:50:16 GMT -5
Yes starter turns when bridged all wiring appears correct. But I cannot find power to the ignition switch. The engine sparks fine being AC when ignition turned on. My next thoughts are go through the sidestand, clutch and brake cut out switches then the kill switch before I have to clear the ramp for the mechanic to use Monday.
Post by milly on Jan 29, 2023 9:48:04 GMT -5
Well checked everything nothing tried what I did before and run extra wire to the solenoid low current feed and everything started working with ignition off or on. Removed wire and tried again and only working when ignition switch is on. A result but how I have no idea. The joys of electrickery.
Post by milly on Jan 29, 2023 11:36:22 GMT -5
Completed wiring other than head and tail lights, bit of carb cleaner down carb and runs. Petrol tomorrow see how good it all is.
Post by milly on Feb 8, 2023 17:05:45 GMT -5
Slowly moving on with it now scooter nearly sorted. Low down stuff done this evening as ramp needed back by mechanic.
Post by milly on Jul 28, 2023 8:57:45 GMT -5
Been a while since getting this shed together. Wondered why problem getting parts. Been ordering Lexmoto Michigan and not Arizona parts doh. Well new carb, battery and other assorted bits I can't remember. It's now running up and down the road needs a but more doing to it but will sort that shortly in a month or so.
Post by milly on Aug 14, 2023 11:52:51 GMT -5
Getting nearer to the end, rear mudguard and light fitted partially today
Post by milly on Aug 15, 2023 10:15:03 GMT -5
More done today slowly getting there. Couple of holes to drill and wiring to finish off on the back end then headlight bulb footrest bolt to drill out then maybe off for MOT.
Post by milly on Aug 21, 2023 4:18:40 GMT -5
Road test on the Rat today. Lexmoto Arizona only problem is when opening throttle but think that's down to the Heath Robinson airfilter intake tube being a old fork gaiter and is collapsing. Bothered? Nah just another bit to throw away and lighten the load, saves me losing weight 🙃
Post by milly on Aug 22, 2023 11:40:15 GMT -5
Post by jackrides on Aug 22, 2023 12:13:42 GMT -5
Looks Great! Glad it passed the Alicia test!
Post by milly on Aug 23, 2023 1:47:06 GMT -5
Post by milly on Aug 23, 2023 10:11:49 GMT -5
Post by milly on Aug 28, 2023 18:28:40 GMT -5
Don't yer just love crusty electrickery
Post by milly on Sept 7, 2023 10:55:14 GMT -5
sinfull
Post by sinfull on Sept 8, 2023 4:07:29 GMT -5
Bike looks great 👍 I would ride it till the wheels fell off.
Love the surviver look 😍 kept on road by creative repair 😆
