Post by FrankenMech on Apr 7, 2024 12:56:57 GMT -5
I have heard diameter matters... LOL
That shaft just needs a stretcher. I have heard of people hanging a weight from the end.
Post by milly on Apr 25, 2024 11:55:38 GMT -5
Got the gears and selectors in after following Haynes manual with a arse about face picture I was trying to follow. Needs a Clymer manual they were much better. Then to put the other half of case on to test gear's select ok and can't find a little roll pin. Dammo will have to wait till tomorrow when my amazing memory kicks in.
Post by FrankenMech on Apr 25, 2024 13:04:30 GMT -5
Can't you buy a roll pin at the local hardware store? If you were at my place we could dig through a couple boxes of assorted roll pins and cut one off if needed. I have purchased several packages of assorted roll pins or just pins in general, even ball bearings, clips, circlips, E-clips, snap rings internal/external, or many springs over the years. I even save hardware like that in boxes and bins. One never knows what they may find...
Post by milly on Apr 25, 2024 13:20:49 GMT -5
I do have some somewhere or local hardware shop will have them individually.
Post by milly on Apr 25, 2024 15:43:14 GMT -5
Well after visiting my mum with son,his wife and the dog I got home and said to Yolanda gonna look in the shed for it for 10mins and then I know whether to look in the garage by house or across the road tomorrow. Found a spare in the new set put in tested the gear's and they all select. Phew! Happy bunny 🐰
Post by jackrides on Apr 26, 2024 15:19:31 GMT -5
HOORAY! Sounds kind of like going to another room for something, forgetting what it was, going back to the starting point to find the thought, finding it, going back for the item, finding it, going back to chair to rest.
Post by milly on Apr 26, 2024 16:27:00 GMT -5
Well held up again as wrong gasket set sent and have had to order 3 individual ones and use top end set of the wrong one they sent so that won't happen till about 7 days time now. Got Kickstarter in place after heating spring and turning through 90° even the ones listed by suppliers didn't have a twist on them and no way the end is going to secure in the hole. Luckily I had a look at a YouTube video on the Honda CG and noticed it as that's what my engine is based on, a bit more updated and on the downside also corners cut for max profits most likely. But at least it's in.
Post by FrankenMech on Apr 27, 2024 6:43:37 GMT -5
Sounds like you need to figure out how to make gaskets. Cereal boxes, copier paper, or paper bags make good general purpose gaskets depending on the thickness needed. I have also used brass shim stock for metal gaskets. Transfer punches are handy for hole locations. I often use spray photo-mount adhesive on one side and grease on the other during installation. Good old permatex aviation form-a-gasket works well as a gasket material especially where petrol or gasoline exposure occurs, a small tub with a brush will last you 20 years. I suspect the aviation form-a-gasket would even work as a case sealer, it doesn't take much, just a very thin film. Most people use WAY too much RTV or sealants which can cause squeeze-out and small pieces that can block passages or ruin pumps or bearings.
