Post by silver03zuma on Mar 15, 2023 8:52:02 GMT -5
Hi, my 03 50 2T has just an expansion pipe and rollers. Trying to keep oil injection. It leaks oil and is hard to start and smokes a lot. After riding and it sits for a few hours, the oil pooling starts again underneath onto the ground. Hard to pinpoint where it’s coming from. I go to start and the bike sounds and feels flooded. When it starts It smokes a lot and for a long while. Cranking it over and over again causes the carb to overflow to the ground and it looks like heavy oil presence in the fuel. When i drain the carb bowl i can see oil in the fuel. After draining it starts amazing. And it’s good riding until it sits again for a few hours.
I found a thread that the check valve in the carb could be stuck allowing oil through the carb when it sits. I took the carb off and removed the press fitting and saw the ball bearing and spring. Didn’t look stuck. To test it, I used a new Amazon replacement carb, thinking the OE relief spring or BB could be suspect , and it improved starting very slightly but it still experiences the same symptoms. I am not sold on the aftermarket inline relief valve another user recommended. I am wondering if I crossed cables to carb - throttle and oil injection - and I am activating the oil pump that way. Anyone have pictures of the cables so that i can verify? Also i am wondering if I can adjust the oil injection cable at the throttle and add / remove slack? Any one have experience with that? Finally there are China aftermarket oil pumps on eBay but most people say the stock ones are crazy reliable so I am hoping it’s just another simple solution and I can keep OE. I tried premix as a test leaving all stock oil injection parts in and the problem went away. I am trying to save the oil injection system though. Any help is appreciated!
